| | | Forums66 Topics128,082 Posts1,056,303 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 40 Member | | Member Joined: Aug 2006 Posts: 40 | Will late model Silverado/Yukon/Suburban 16" 8 lug wheels fit this thing? If not, are there any decent looking junkyard wheels that will fit? Mine has the original 3-piece suicide wheels. Thanks, Dash | | | | | Joined: Jun 2006 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 49 | What you have to watch out for is back spacing. Its very tight. If I recall correctly, its about 4 and 1/4 inches. This is because of the tie rod ends. I have a '51 3/4 ton and been there. I found 16" dexter wheels at a trailer shop. Google on dexter and you'll find a couple of places. Dexter doesn't make them anymore but there are still some around. I had to put my own clips on them but they look good. Click on THE SLEEPY DRAGON link below to see them. You can replace the tie rod ends with more modern ones and buy yourself some back spacing and then might be able to use those wheels you refer to. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 16s for an '80-'87 4x4 should work, too.
Bill Burmeister | | | | | Joined: Aug 2006 Posts: 40 Member | | Member Joined: Aug 2006 Posts: 40 | Sounds good guys. I'll give them both a shot.
Dash Riprocker | | |
