3 members (Gdads51, Ponchogl, mick53), 39 guests, and 2 robots.
Topics128,090
Posts1,056,018
Members48,430
#21326 04/17/2002 7:29 PM
I'm ready to hookup my external oil canister on my 235. Is there anything special I need to know (adding oil...?) or is it a matter of just installing and cranking? Thankful for any help.
It is a bypass oil filter so it won't hurt if oil doesn't flow out of it for a while but you should fill it with oil before start up so that oil doesn't flow into it too fast or the bearings might be starved until it fills up enough so that oil is flowing through the restrictor instead of air.
Paint & Body Shop moderator
