| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | I have a beater 49 3100 that I would like to make drivable without putting to much money into. I have a 79 Nova rearend that I believe has 2.56 gears. I also have a stock 4sd from a 63 Suburban. When I used to drive the Suburban I only used 2nd, 3rd and 4th. If I used the Nova rearend with the 63 4sd, would I basically have a 3sd with overdrive. If 4th gear was 1.00, the RPM calculator shows 2150 RPM @ 70mph with 28" tires. It seems like with this combo I would use 1st, 2nd and 3rd. 4th would be like an overdrive. Maybe I'm way off base but I'd like to use some of the parts that I have laying around. Does anybody know what the gear ratios are in this tranny. Any thoughts on this? | | |
