2 members (Dennys28, 1 invisible),
93
Mod | | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 52 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 52 | I just got a 48 that someone tried to put on a 83 S10 frame. Is there any where I can get info on how to do this? Any forseen problems?It already has the V8 and 350 turbo in it.The cab is just sitting on the frame .Maybe someone out there has done this and could help. Thanks | | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | Hot Rod,
Welcome to the order of S10 frame swappers. Run a search on this site and you will pull up some info.
A yahoo search for "s10 swap" will give you tons of info to sort through. I am doing a 38 truck swap and I know the Advanced Designs are done all the time. Your Art Deco in the middle should be doable too. Time, skill and money are all it takes.
Good luck with your project!
Jim
Jim
| | | | | Joined: Jul 2006 Posts: 11 Junior Member | | Junior Member Joined: Jul 2006 Posts: 11 | Hot Rod; Call Accessoryland at (563) 556-5482 and ask for Bob. He put a beautiful '52 Suburban on I believe a '97 S-10. It was really well done. | | |
