0 members (),
160
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | $34.00 worth of wood... along with new bed strips, paint and hardware.... And a lot of time... Cutting the boards, applying marine spar varnish, painting the bed strips all took time. But I think it turned out pretty nice for the few bucks I have invested in this part of the project. My father-in-law and I spent a couple of hours cutting the bed boards to fit. My old boards were good enough to use as a pattern. So putting it all together is how I spent my saturday. Best part was having my 11 year old daughter help. She likes to help when we see progress fast! | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Looks really good. Want to come and do mine? It will be due within a year! | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | Looks good, are you going to haul stuff back there?
I'd like to put a fancy bed in my bolt eventually, but I'll also make install brackets? or whatever so i can slide a piece of plywood in so i dont dork up the prettyness. Maybe a slide in bedliner?
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | R/R,
My goal is to build a Daily driver. I could have gone oak, but thought I would never drop a speck of dirt on oak. I tried to go to clear pine, but that big center board only came in slight knot grade (#3 or something like that) for a board that wide. There are saw mills that would probably do custom boards, but they are two hours away. With the price of gas and all, I figured a few knots were not going to kill this project.
As far as hauling, a piece of chip board or plywood on the bottom should protect the pine when hauling rock, dirt or other "honey do" items.
As far as tools to cut the boards, we installed a Dato (sp) blade on the radial arm saw and cut from the top. A couple of hours at most and we were done. Setting up the saw took the longest. Once that was done, the cutting obviously only took a few minutes. It may not be up to show quality standards, but probably one of the most satisfying jobs on the truck so far!
The plan is to re-do the body in a few years. If I decide to go oak, I am only out $34.00 for the pine. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | The pine looks good,and the knots give it some character.My 55 has a cherry floor,and the 72 has an oak floor.No hauling in these trucks,just a couple of bagged up lawn chairs to use at the cruisins.I used a spar urethane finish on mine,brushed on 4 coats,with a lite sanding between coats,then sprayed the last coat on,for a mirror like finish. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | 46 in progress,heres a good tip to keep that floor looking good.Go to your local Home Depot and buy a can of Min Wax Paste Finishing Wax,and put on a coat of this every 2 mos.or so.It keeps that nice shine to it.I believe Johnsons also make a paste wax for wood. | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Thanks for the tip Dale! Much appreciated.. | | |
