6 members (TUTS 59, Stovebolt48, 32Fordpuchoptop, Wayne67vert, Oswald, Otto Skorzeny), 83 guests, and 9 robots.
Topics128,021
Posts1,055,348
Members48,420
#21221 07/29/2003 5:56 AM
Hi, Can anyone help me figure out what I have here (or where to look )? The engine is in a '47 AD 2 ton, but not likely the original as it has a shop tag showing a rebuild (with bore .40 over).
The block number is F1127JC, The head is 3836848.
The valve cover reads Chevrolet. The engine was painted blue (which may not mean anything).
Thanks, Dennis in Shawnigan Lake B.C.
Royzell
F=Flint Michigan
11=November
27=Day
JC=1958 to 1962 235 engine
The 848 cylinder head is a good cylinder head
Welcome to the Stovebolt cool
Thanks, much appreciated.
The code looks simple once you know what it is.
Royzell
Hey Mechainiac,
How about B262. I know it Feb of 62, but what does the B stand for ?
Craig
My turn...the number (if it is right above the starter) is CON4 J 36 The casting numbers of the motor/head are as follows 3837004 GM8 and 3835913 GM 9. The frame is suppose to be a 57. Any help this direction?
Use a big enough catapult and even pigs can fly...remember nothing is impossible, impractical yes, but never impossible.
What does that CONV...mean
the number on my block is CONV3...CH 188
Someone on the list told me my engine was built
in Sept..1948...
How did they get that?...thanks in advance..
1946 chevy 1/2 ton panel
1937 ford coupe
The CON means the line it was produced on at the factory, like CON3 is assembly line 3.
Paint & Body Shop moderator
