| | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21221 07/29/2003 5:56 AM | Joined: Apr 2003 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 67 | Hi, Can anyone help me figure out what I have here (or where to look )? The engine is in a '47 AD 2 ton, but not likely the original as it has a shop tag showing a rebuild (with bore .40 over). The block number is F1127JC, The head is 3836848. The valve cover reads Chevrolet. The engine was painted blue (which may not mean anything).
Thanks, Dennis in Shawnigan Lake B.C.
Royzell | | |
#21222 07/29/2003 11:54 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | F=Flint Michigan 11=November 27=Day JC=1958 to 1962 235 engine - The 848 cylinder head is a good cylinder head Welcome to the Stovebolt
#21223 07/29/2003 3:06 PM | Joined: Apr 2003 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 67 | Thanks, much appreciated.
The code looks simple once you know what it is.
Royzell | | |
#21224 07/29/2003 3:38 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Hey Mechainiac, How about B262. I know it Feb of 62, but what does the B stand for ?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#21225 07/29/2003 8:49 PM | Joined: Jul 2003 Posts: 29 Member | | Member Joined: Jul 2003 Posts: 29 | My turn...the number (if it is right above the starter) is CON4 J 36 The casting numbers of the motor/head are as follows 3837004 GM8 and 3835913 GM 9. The frame is suppose to be a 57. Any help this direction?
Use a big enough catapult and even pigs can fly...remember nothing is impossible, impractical yes, but never impossible.
#21226 07/29/2003 11:37 PM | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | What does that CONV...mean the number on my block is CONV3...CH 188
Someone on the list told me my engine was built in Sept..1948...
How did they get that?...thanks in advance..
1946 chevy 1/2 ton panel 1937 ford coupe | | |
#21227 07/30/2003 5:38 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The CON means the line it was produced on at the factory, like CON3 is assembly line 3.
