4 members (55shaker, classicfins, Charles in CA, CandoBrent), 113 guests, and 3 robots.
Topics128,128
Posts1,056,664
Members48,450
Junior Member
Junior Member
Hello stovebolters! Does anyone have an idea of how to install a 1952 228 gmc engine on a 1950 chevy chassis? I know for a fact that the gmc engine is longer then the chevy engine so the radiator has to move up a couple of inches. Can anyone tell me if they have this kind of setup? And if you do how did you get over this obstacle.
there is a tech tip on the inliners web page.
Junior Member
Junior Member
IT DOESNT REALLY SAY ANYTHING ABOUT TRUCKS THOUGH!
copied and pasted from an earlier post
wynns55
Apprentice
Stovebolter # 9219
posted 10-31-2005 05:14 PM
I recently bought a 1950 chevy 3100 with a tired 216 engine, and wanted to know if the gmc 270 will bolt up with the chevy transmission and or motor mounts with no problem. I been told that the radiator has to be moved up a inch.
Posts: 27 | From: hailey,idaho | Registered: Oct 2005 | IP: Logged |
OldSub
Stovebolter # 3837
posted 10-31-2005 10:05 PM
Radiator needs to move forward and your front motor mount is different. Flywheel is different, otherwise transmission and bellhousing will work.
I have a GMC 270 and love it.
[email protected]
www.OldSub.com
55.1 GMC Suburban driver
49 Chevy 5-window 3100 Hot Rod Project
50 Chevy 1-ton dually flatbed
52 Chevy COE Suburban Cargo
52 Chevy 6400 (slightly mashed) Parade Truck
72 Chevy C-10 work truck
...as I see them!
Posts: 2672 | From: Seattle, Washington | Registered: Oct 2003 | IP: Logged |
reo_guy
Stovebolter # 527
posted 11-01-2005 07:45 PM
You will have to butcher the radiator crossmember to move the radiator forward. A neater approach is to get a GMC radiator and radiator crossmember. Cut off the top 2/3rs of the GMC crossmember and weld it to the bottom 1/3 of the chevy crossmember. The GMC radiator will be in the right spot. You will have to trim the top of the hood latch panel slightly. Few will notice that it is not stock.
Jason
Posts: 416 | From: southeast SD | Registered: Aug 2000 | IP: Logged |
