4 members (ndkid275, Hush, frogfarmer, BillCollins), 101 guests, and 0 robots.
Topics128,087
Posts1,055,974
Members48,430
#21194 11/16/2001 6:14 AM
Well, I have a lead on another 261. The guy has 2 of them in his garage. He told me to make him an offer on one of them, but I have no clue....anyone got a ballpark figure? They are complete.
1955 Chevrolet 210 2 door Sedan
a 30,000 mile UNMOLESTED original, now my daily driver! Original 6 cylinder with a rebuilt '66-'69 Saginaw 3-speed Overdrive. Synchro low! Otherwise, everything original down to the spare tire. Interior is like new. Needs paint, but absolutely zero rust.
#21195 11/16/2001 7:52 AM
First question - Do they run?
Fred
52 3600
69 C-10
#21196 11/16/2001 8:35 AM
Sold mine for $60.00, wasn't running. Turned out fiber timing gear was broken and that was all.
Make a low offer and work from there.
Good luck,
Rick
62 1/2 ton FS SB big window
With all the torque in the newly built 454, will the motor stand still and the truck spin around??
#21197 11/16/2001 11:49 AM
All 261's have aluminum timing gears as do 235 engines out of trucks.Must have been a cam change .
#21198 11/16/2001 9:56 PM
Tony,
Very possibly could have been, but not by me. Not sure how many PO my truck has been through, or what was done, or even if the engine was the orginal. Id it from block numbers. I wanted to drive it while the big block is being built and it cooperated for several months, wished it would have lasted longer, I miss driving it alot.
It will come back, bigger, better, and stronger.
Can't wait.
grin grin
Rick
#21199 11/17/2001 12:24 AM
No, I dont think they run. Not a prob for me because i'm going to rebuild it.
#21200 11/17/2001 2:40 AM
V
V Offline
Any more $60.00 261's in So.Cal. ? give me a call or respond to my other e-mail addy :
[email protected]
THANX !
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#21201 11/17/2001 5:02 AM
Around here you can buy a complete non-running 261 for $150-$200. I'd start at $100, you can always go up.
Fred
52 3600
69 C-10
#21202 11/18/2001 11:16 PM
Thanks for the replies guys, i'll keep them in mind!
Chad
