1 members (1 invisible), 107 guests, and 3 robots.
Topics128,159
Posts1,056,900
Members48,458
#210743 06/27/2006 3:42 AM
Junior Member
Junior Member
Just looking for some info,I'm fixen to start my 1956 project,I will be putting a small block back in it,seeing how the ole 235 is laying out in the sand at the farm,Will the original rearend stand up to the small block.Have not had the time to really look at the rearend,just wondered if anyone has played with one in here.
so many trucks ,so little time
That rear should hold up fine to a small block. However, there are not too many parts for it other than seals and gaskets. There is a 3.38 gear availible, unfortunatly there are no aftermarket posi units availible.
Bill Burmeister
Junior Member
Junior Member
That was something ,I was afraid of,I'm building it to just cruise around on weekends .I have 2 12 bolt and 1 10 bolt rearends but did not see the point of putting one in something that I was not going to put under higher Hp engines.but sounds like be easier to put one in ,and save time on finding parts. Thanks for the info
I hadta rebuild the one in my 57 panel years ago - not hard, and everything is available except the axles, which are around used - I found a used complete carrier easily - I later got a 3.90 NOS complete carrier w/ all gears and bearings, and the rear end place said they didn't want it as part trade on a 3.38 set cuz they got lots and no demand!
a stock rear is standing up to my buddy\'s built 427 , and I've seen him pull the front wheels off the ground - the original will be fine unless it's already got chewed up teeth
if it ain't broke, don't waste effort fixin it!
I agree with you, red. I wouldn't change it uot either. I forgot to mention that bearings were availible, my bad. I didn't realize that the internals were availible though. Guess I spent too much of my time hunting parts for them getting frustrated that there aren't any posi's for them. Oh yeah, the seals can be found anywhere thet has National brand seals.
Bill Burmeister
I am running a 350 in my 55 2nd,along with a 700R4 tranny.A great setup.Plenty of performance and great fuel economy with the OD tranny.The stock rear is 3:90 and hooks up great with the OD tranny.
Junior Member
Junior Member
Thanks everyone ,been working alot and have not had time to get back on here,but thanks for all the info,it is a big time saver.
