0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#209840 06/12/2006 6:48 PM
In a 1953 1/2 ton, there is a sloping metal pan that connects to the frame under the radiator and comes forward to the bottom of the grille. I cannot find it in anyone's catalogue (ours is in not the best shape), but I also do not know what to call it. It looks like a baffle of some kind; I do know that it is not the "bumper apron," though. Maybe I could find it if I knew what to call it.
#209841 06/12/2006 7:11 PM
valance?
Another quality post.
Real Trucks Rattle
#209842 06/12/2006 7:24 PM
Ex Hall Monitor
Ex Hall Monitor
I'm not sure about the 53 but it's probably the lower radiator baffle. I'm not sure when Chevy stopped using that piece but your description fits the lower baffle in my 38.
#209843 06/12/2006 7:25 PM
The bumper filler panel or valance is often called a splash shield or splash pan. The panels that cover the gap between your runningboards and bedsides are called aprons.
The other shield(s) I think you may be talking about is called a stone shield. If your 53 is like my 50 GMC there are 3 of them, with the "sloped" panels on the ends and a more rectangular panel in the center. I've never seen them in a catalog, on ebay, or anywhere else.
Mike Barnes
1950 GMC 1-ton pickup
#209844 06/12/2006 7:26 PM
If the 'pan' you are talking about goes between the fenders, behind the grill and at the bottom of the radiator, it is the 'radiator pan' or 'radiator valance' or 'radiator pan valance' or 'lower radiator shroud'. I think 'radiator pan' is the most common name.
With the grill off you can see that one of its purposes is to funnel the air into the radiator as well as keep the lower part of the front fenders together.
There is a thread on where to find one here somewhere. Try searcing 'radiator pan' or 'radiator valance.'
Someone put '54 fenders and grill on my '51 pick-up and I wanted to put it back to stock so I had to find that same piece. I've noticed a few on e-bay from time to time. They are out there, but only used or NOS, no re-pop.
I suggest posting in the 'parts wanted' forum.
#209845 06/13/2006 1:04 AM
I bought one years ago from jim carter . He carries new and used parts.You might want to post in the parts wanted section.I'm sure someone will have it.Good luck with your truck.
1951 3100 Chevrolet
