2 members (Cosmo, Wayne67vert), 43 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#209223 06/07/2006 3:34 PM
Hi folks,
Yes I'm new to the stovebolt, looks like a great source for info. I just purchased a 58 GMC stepside, never having restored an old truck I will be asking for alot of advice. My first search is for an updated front end. My wife will probably drive this truck so it has to have power and disc, any suggestions on a good donor would be greatly appreciated.
Tbone
#209224 06/07/2006 5:55 PM
Hey, Tee-Bone,
You have two choices: 1) Stay with the solid axle, 2) Get yourself a front clip from a later-model rig.
The solid axle can be given power disc brakes and power steering, but it takes a little fabbing. A front clip is a major project and should be done by someone who really knows their stuff, but can provide a more car-like ride. Of course, you won't have the soul of an old truck, then.
Everything's a trade-off, Buddy.
Good Luck!
#209225 06/07/2006 6:48 PM
Thanks for the input.
I would like to stay with the solid axle, I
thought that would be harder to do than change it over.
#209226 06/07/2006 7:54 PM
Junior Member
Junior Member
1 Offline
Did you mean power disk breaks or power steering and disk breaks?
The way I see it you can either go to work or you can fly airplanes...Me I think I’ll fly.
SCF
#209227 06/07/2006 8:05 PM
There are some that have commented that bolting/welding a mustang II front suspension under these trucks isn't too hard.
I've driven a fully restorted stock truck without powersteering and didn't miss not having it. However, I didn't have to parallell park either...
Adding disc brakes to the front solid axel isn't too hard. If you do the conversion you might think about doing your kingpins and wheel bearings at the same time.
#209228 06/07/2006 8:36 PM
Maybe I'll try to convert the existing.
The truck is completly stripped down so everything will be new or rebuilt, HOPEFULLY.
