4 members (Gdads51, 55shaker, MickeyP, 59 fleet), 79 guests, and 1 robot.
Topics128,118
Posts1,056,304
Members48,439
just wondering, i came across a nice custom cab for my 66. no deep rust/dents and has that awesome big back window, only problem is that its off a c-20 or c-30. im not sure which, but the overall size of the entire truck tells me for sure its not a half ton. are the same cabs used for half ton on through one ton?
It's my understanding that the same size cab is used from 1/2 ton through 1-ton. The fenders will be different on the bigger trucks, for tire clearance, but the cab should be the same.
I think the cabs are the same even on up through the mammoth 60 series, for the years 64-66. Like Hotrod says the fenders are much larger on the bigger, medium duty rigs (40-60 series).
-magic mike-
thats what i thougt thanks again for the quick and acurate response guys
The cabs are the same except the front cab mounting holes are in diff locations due to frame widths being different. Easily modified & hidden under the floor mat. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
