| | | Forums66 Topics128,132 Posts1,056,376 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20877 11/28/2004 7:50 PM | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | just wondering, i came across a nice custom cab for my 66. no deep rust/dents and has that awesome big back window, only problem is that its off a c-20 or c-30. im not sure which, but the overall size of the entire truck tells me for sure its not a half ton. are the same cabs used for half ton on through one ton? | | |
#20878 11/28/2004 7:54 PM | Joined: Feb 2004 Posts: 29,811 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | It's my understanding that the same size cab is used from 1/2 ton through 1-ton. The fenders will be different on the bigger trucks, for tire clearance, but the cab should be the same. Jerry
#20879 11/28/2004 10:34 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | I think the cabs are the same even on up through the mammoth 60 series, for the years 64-66. Like Hotrod says the fenders are much larger on the bigger, medium duty rigs (40-60 series).
-magic mike- | | |
#20880 11/29/2004 8:22 AM | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | thats what i thougt thanks again for the quick and acurate response guys | | |
#20881 11/29/2004 4:27 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The cabs are the same except the front cab mounting holes are in diff locations due to frame widths being different. Easily modified & hidden under the floor mat. Brian | | |
