9 members (WICruiser, Youngin' Tut 59, Rick Brown, Gdads51, Hotrod Lincoln, KEVINSKI, 3800GUY, TUTS 59, 1 invisible),
106
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,116 Posts1,056,589 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20869 02/23/2002 7:49 AM | Joined: Feb 2002 Posts: 4 Junior Member | | Junior Member Joined: Feb 2002 Posts: 4 | I have found a company called Art Housers Rear Ends that sells 3.90 and 4.11 gear sets for the 3/4 and 1 tons. Has anyone out there done business with them or heard anything about them? Also, let me ask you guys this. Will the ring and pinion from the 66-72 heavier duty rear ends fit the earlier 47-53 3/4 and 1 ton? And my last question, thanks for your patience. My rear end has a large bolt on the side that goes into the case right in line with the pinion. I assume that it adjusts the pinion somehow. Anyone know what it does? Thanks a lot! I have picked up so much from this site already. You guys are great. | | |
#20870 02/23/2002 8:19 AM | | Anonymous Unregistered | | Anonymous Unregistered | From what I have read in the past on this site, 3/4 and 1 ton EATON differentials are interchangeable from 47 to 72. There are several threads that touch on this topic. HEre is one that might get you started . . . | | |
#20871 02/23/2002 8:32 AM | Joined: Feb 2002 Posts: 4 Junior Member | | Junior Member Joined: Feb 2002 Posts: 4 | Thank you Mr. Brown, I learned a lot from that thread. | | |
#20872 02/24/2002 4:38 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I think it was Bubba that had a bad experience with houser. Houser was advertising that his gears would work in the older style pumpkins, Bubba bought one and found they wouldn't. He did get his money back. At the same time houser was stating on his website that he was the only one who was having the gears cut, he wasn't. Randy's Ring Pinion was making them too. Personally, I would not do business with houser beacause of this. My recommendation is to find a pumpkin with 4.10 gears or better if you're lucky, and make the swap. Best bang for your buck.
With the price of a new set of gears, you would be better investing your money in a late model differential and having it narrowed. There is a 3.5 inch difference in width, a 1.25 difference in setback and a 1.5 inch difference in wheel width, it adds up to a narrowing job of 2.5 inches to maintain the same centerline on your rear wheels.
Fred 52 3600 69 C-10
#20873 02/25/2002 11:40 PM | Joined: May 2001 Posts: 115 'Bolter | | 'Bolter Joined: May 2001 Posts: 115 | I too have made this change. I bought a whole pumkin at a local pick and pull for $65. All you do is pull the axels and drop the whole unit in. Only took a couple of hours and really dropped my RPM's. Many 3/4 tons from '68-'72 with auto trans have 4:11 ratio's. Just make sure they are Eaton.
Brian D
#20874 02/26/2002 12:07 AM | Joined: Jan 2002 Posts: 11 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2002 Posts: 11 | | | |
#20875 03/01/2002 9:40 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | 53OneTon:
That large bolt in line w/ the pinion is for adjustment of a thrust pad inside the gear case, that is on the "back side" of the ring gear: it is supposed to limit the deflection(distortion) of the ring away from the pinion, when pulling under heavy load. It should not be tampered with unless you are planning on "setting-up" the whole punkin; although the shop manual does discuss its adjustment.
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
#20876 03/04/2002 5:08 PM | Joined: Nov 2001 Posts: 7 Member | | Member Joined: Nov 2001 Posts: 7 | How do you tell if a differential is an Eaton? Thanks David | | |
