| | | Forums66 Topics128,080 Posts1,055,945 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20841 02/15/2004 4:58 AM | Joined: Oct 2003 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2003 Posts: 94 | I just found a complete (almost) '54 235 engine with the factory PCV setup. All it is missing is the fan blade.
So, did the '54 235 use the same fan blade as the earlier 216/235 engines? Or, did they use the same blade as the later (55-62) 235 engines?
Thanks Steve | | |
#20842 02/15/2004 4:13 PM | Joined: Jan 2001 Posts: 1,423 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,423 | Don't know the answer to your question but could you post a couple pictures of the original pcv system or email them to me? I'm sure a few people would appreciate a good look at a stock pcv system. Thanks, Cosmo.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#20843 02/15/2004 4:25 PM | Joined: Oct 2003 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2003 Posts: 94 | I'd be happy to post some pictures. But first, I've got to get the engine home and back together. I've taken off the air cleaner, carb, manifolds, generator, fuel pump, breather pipe and distributor so they don't get banged up when the salvage yard folks yank it out of the truck next week. I don't think they are too careful sometimes. I also wanted to make sure I got all the parts. Anyway, when I put it on the stand to clean up, I'll put the PCV setup back on it and take some pictures with my Dad's digital camera. Can't afford one of my own 'cause this truck is eating me out of house and garage! But, I still want to know about the fan blade issue. Anyone out there know???? :confused: | | |
#20845 02/15/2004 6:37 PM | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | I used this engine in my 51.The 216 waterpump and fan bolt up eliminateing the need for a short shaft pump.Ididnt get a fan or pump with the engine so i dont know if the blades are diferent or not.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | |
#20846 02/15/2004 7:12 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Blades are not the same. Fan from my 52 216 would not work on my 54 235, blade was hitting the balancer. Had to track down the blade that came on the 235 and use it.
Fred 52 3600 69 C-10
#20847 02/16/2004 3:09 AM | Joined: Feb 2004 Posts: 85 Member | | Member Joined: Feb 2004 Posts: 85 | I looked at a pre 235 c.i. truck once and it had a big gash in the hood from launching a fan blade thru it after a 235 was put in it, and have heard several times since from old timers that that was common when people put in a later engine but still used the early fan blade,they wern't made for higher RPM's or torque or??? truth or fiction? I don't know, and I didn't buy the truck btw.
Can I add a question to a question? Were there 5 bladed fan blades used on bigger trucks that work better on the little trucks?, I heard this somewhere, and since I'm towing an old camper trailer I'd like all the extra I can get,,,,,ALOHA!!! | | |
