5 members (1955 1 Series, Wayne67vert, Ponchogl, 3B, Guitplayer), 98 guests, and 2 robots.
Topics128,261
Posts1,058,345
Members48,485
#20776 06/28/2002 1:16 PM
Hey folks, I've got a fuel pump question. Last night I pulled the fuel line from my 216 to measure and replace it. The last time I did this a few years ago on a 235 I don't remember having any problems, but last night when I disconnected the line gas wouldn't stop pouring from the outlet fitting on the pump. The pump seemed to work fine before, except for hard starting if the engine hadn't been run for 5 or 6 days. Does the pump have a check valve that's supposed to prevent this? Should I remove it and check it out? The carburetor was pretty dirty inside and I'm cleaning it and putting a kit in it. It's a Carter w-1. Thanks, Jacques
Union, Justice and Confidence
#20777 06/28/2002 7:43 PM
Gas running out when you disconnect the line is normal. You might ad a filter if you see dirt in the system.
if it dosen't need fixed, break it
#20778 06/29/2002 2:14 AM
Thanks Kedso.
