2 members (gswbbc, wilbur53),
139
Mod | | | Forums66 Topics128,035 Posts1,055,446 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | I have about exhausted my brainpower on figuring how to make my alternator bracket fit on the remanufactured 250 that I have put in my truck. The alternator needs to be about 11\16" farther forward than the bracket will allow. I thought about adding on to the bracket, but it looks like it is made of pot metal, so I'm not sure it can be welded. The bracket fit the same alternator on the original 250, however this one seems to be a mystery block. I can't find an Id to match the casting numbers, and the boys at Jasper who rebuilt it can't tell me what the heck it is out of either. The bolt holes for the bracket match those on the block. It just isn't far enough forward to line up with the crank or water pump pullies.
If any of you have a bracket off a 250 a pic would be appreciated. This is keeping me from starting the new motor, trying the new power steering and getting the truck to a place where I had hoped to do some body work.
To say the least it has become very frustrating and bogged the project down.
HELP!! | | | | | Joined: Sep 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 310 | Can you put some washers behind it and use a tat longer bolts? And tell us what the casting numbers are and someone here will tell you what is happening there.
Richard | | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | The casting number on the block is 3994256. I could put washers on, but that would just move the mount further from the block. It mounts on the side of the block. I need to move it forward. | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | I'm using a the outer groove on a double alternator pulley, for reasons other than yours, but it sounds like just the right distance for you. | | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Chuck,. I have both a one and two groove pulley. The two groove JUST misses and the one is off 11/16. Looks like I may have to make one.
Thanks for the help!! Bob | | |
