2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
I sat my 55 on jack stands and noticed when I pushed on one tire it would turn at least 1/2" to 3/4" before the other tire would move. And when the other tire started moving it was hardly turning as much as the one I was turning.
Roger
http://www.flickr.com/photos/45469713@N00/?saved=1
Although it seems strange, this is not a problem. It is what a differential is supposed to do. It is kinda hard to explain, but if you popped your rear cover it would all become clear. The axles are designed to be able to turn at different speeds through the use of planetory gears. The reason for this is basically geometry, in going around a corner, the outside wheels have to travel farther then the inside wheels. (Think about the last time you saw a (non-posi) vehicle stuck in snow or mud, one wheel can be spinning 40mph and the other not turning at all.)
Steve O
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
Riding in the Passing Lane
Put the trans in gear & then try it.
1972 Chevy c10 Cheyenne Super
When I put it in gear I have about the same abount of slack if not more.
Roger
Roger
Sounds like you have a lot of slop somewhere. If it,s not in the drive shaft pull the rear cover off the diff. One wheel should not turn more than an in. or 2 before the other wheel turns in the opposite direction. There should be no up or down motion inthe pinion flange & only about 1/8 to 1/4 in. turning free play. The carrier that the ring gear rides on should not have any side to side movement no more than .012 in free play. Examine the spider gears & shaft.
