| | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 30 Junior Member | | Junior Member Joined: Jan 2004 Posts: 30 | every clutch head screw on the door panel is rusted and fused into place. what will be my best option? drilling? retapping? i would like to remove to clean out the several inches of dirt and seat fluff that is trapped at door bottom. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Do you have finish paint on the door? If you can repaint then use a small torch tip(like 00) to keep the heat on just the head of the bolt. Heat to very red and let cool, then heat to a dull red a second time and they will break loose nearly everytime. This is definitely hard on clutch head screwdrivers but you can grind them back several times before you have to can them. If finish painted you can try the various rust busters(we like Aero Kroil), or as a last resort you can roll the window down, block the drains, and maybe get them soaked with plain old water for several days. This is the way we get frozen brake drums off and it works very well. Water turns the rust to slime and kills it's holding power. The only thing is if you got all that gunk wet thats in the door bottoms you would HAVE to get them cleaned out. One last tip, if the clutch heads strip you can cut a groove for a slot head screwdriver with one of the thin high speed cut off blades. Good luck.
Evan
| | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Most of my screws where rusted also, I used my cut off tool and put a straight groove in it, then used a manual impact driver to loosen them up. I planed on replacing the screws anyway so it was not much of a loss. Hope this helps.
Ed | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Try putting the tip in the head, then whack it with a hammer a couple times (like you'd hit a chisel). That often frees up small fasteners (like philips heads on trim, door sill trim, etc.) An impact driver also works very well. And just to be sure, you are using a dedicated Clutch head screwdriver, aren't you? I've known a ton of people who try to get by with a straight blade in the clutch head. That'll make a huge difference. I'm fortunate, in that I have a 3-screwdrive set of clutch-head drivers (One old Snap-on, two bought new off the truck a couple years ago for a very reasonable price), and an impact driver with a 3/8-drive socket end. The bits I put on it are made for ratchets--and I have one clutch-head screwdriver bit for a 3/8-inch ratchet. The impact driver has saved my bacon more times than I can count. Most recently, it took care of the philips fasteners on the barn door slides/latches for my '62 Suburban. I'd have been drilling out the old and buying new hardware store fasteners without that impact driver. -Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | I tap the screwdriver while puting inward and turning pressure at the same time.On the most stubourn ones i put a vice grip on thr driver to turn with one hand and used the other hand for inward pressure and had a helper tap the driver.Only had to grind one on a complete dissasemly
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=9;t=000304#000000
Jim
Good luck with your project!
| | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Originally posted by Ed Blouch: Most of my screws where rusted also, I used my cut off tool and put a straight groove in it, then used a manual impact driver to loosen them up. I planed on replacing the screws anyway so it was not much of a loss. Hope this helps.
Ed Yup, that's exactly what I did but I used a hand held, hammer driven impact driver to get them loose afterwards. THIS WORKS!
delete my account and pictures
