9 members (Otto Skorzeny, Cosmo, RAC1812, cmayna, GRNHydra, HandyAndy, Peggy M, 1955 1 Series, 1 invisible),
144
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,982 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Is there a source out there for blank tags? I know Jim carter carries the chevy version. I guess I'll have to keep checking ebay.
Is there a way to fill in all of the blanks on such a tag ie gross vehicle weight, h.p., and model number. I just have the small body number plate under the hood on the drivers side. I'm just not sure if there is a way to put the existing numbers together to come up with the authentic number including manufacturing plant code. | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | The 39-40 GMC ID tags are not reproduced to my knowledge. The ID tag has model number, serial number and gross weight not to exceed number. Your 1940 1/2 ton long bed model number would be AC102. The model number and seriel number will be stamped on the frame on the passenger side above the front axle. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Would an AC152 be a 3/4ton? the rear springs are mounted under the frame, not to the side. | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | An AC152 is a 3/4 ton with a 123 3/4 inch wheelbase. | | |
