0 members (), 136 guests, and 3 robots.
Topics128,193
Posts1,057,259
Members48,466
Junior Member
Junior Member
Is the gmc grille support the same? from what i've seen the dual headlight single top bar grille on the gmc *should* fit the CHEVY. THANKS!
The grille supports are the same, except the holes are drilled in different spots.
I know this since I too installed a '64 GMC grille on my '62 C10. If I remember correctly the GMC grille bolted up to 3 of the 4 bolt holes on either side, just the 4th hole needs to be drilled.
Also both grilles wire harnesses used the same plug on the end of the harness, so it's a plug in & you're set setup. cool
David
My truck don't leak oil, it just marks its teritory.
