3 members (ShopRag, dt235sd, 1 invisible), 359 guests, and 5 robots.
Topics128,154
Posts1,057,015
Members48,460
#206793 04/27/2006 2:27 PM
i know to run 80w90 but i was told that when running 80w90 in a tranny or t-case that your not spose to have any GL content in it, you could get by with GL-1 but GL-0 is preferable cause from what i unstood that GL stuff is the amount of rubber particles in the oil that help the oil stick to gears (in rear ends) and that it'll clog up bearings in a tranny or t-case thuss keeping oil out then causing them to fail so what kinda of oil should i run then? straight weight 30? or higher?
Nate
Link to my photobucket for pics of my vehicles
http://s238.photobucket.com/albums/ff17/OldIronChevy/
Not quite true- You don't want to run straight GL-5 in older transmissions because it has hypoid additive that can pit synchros, but if you use a Gl4/GL5 rated gear oil you will be fine. Don't run straight 30. The GL spec stands for "Gear Lube" and is an API rating, has no bearing as to what is really in the oil.
Paint & Body Shop moderator
