4 members (55shaker, 78buckshot, Otto Skorzeny, Charles in CA), 164 guests, and 8 robots.
Topics128,078
Posts1,056,031
Members48,433
#206281 04/19/2006 2:38 AM
I have a 1939 GMC 1/2 ton Panel Truck with 2 sets of bumpers. One set has two small groves across the blade and the other set has one wider single grove approximately 7/8. Problem? Which set belongs on this truck? They both appear to be similar in length and shape and bolt up to the same brackets. And? Are panel and pick-up bumpers the same? THANKS for your input, Nick
#206282 04/19/2006 1:00 PM
Nick, I don't know about GMC's, but the '39 Chev. used the bumpers with the wide single groove, and the '40 used the bumpers with the double narrow grooves. '39 pickups used the same bumpers front to rear, '39 panel truck had a special rear bumper that "dipped in" in the middle to allow easy close-up access to the cargo area with the rear doors open. The pickups didn't use this special bumper, as with the tailgate down, you never got close to the bumper anyhow.
To be long remembered as he's cruising in
The Passing Lane
#206283 04/20/2006 2:31 AM
The 39-40 GMC had smooth bumpers, no grooves at all. Also the front bumper mounting bar is very different than Chevy.
