| | | Forums66 Topics128,068 Posts1,055,881 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 27 Apprentice | | Apprentice Joined: Apr 2003 Posts: 27 | Will any late model 6-lug wheels fit 47-54 A D chevy trucks--1/2 ton ? Thanks 50 chevy 3100
rrf
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 50chev/Caroline.... the new Colorado chevy pickup has 6 lug and will bolt right on. My friend has put them on his truck. One thing.... he has the fancy wheels and on the front they will rub the inside arm where the tie rod goes. This is easily overcome with a small spacer. I plan to use the colorado rims on my 52 panel. | | | | | Joined: Apr 2005 Posts: 113 Member | | Member Joined: Apr 2005 Posts: 113 | I have late 70's to mid 80's chevy 1/2 ton 4x4 ralley rims on mine. No rubbing problems. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | jeep 6 luggers will i got all 5 of mine for $25.00 my rear end is a 77 burb 6 lugger and i have disc's on the front. Disc's require a wider rim. that's why i had to change to a wider rim. the stock hubcaps can work w/ some sweat equity and a good eye for the clip placement. i believe all chevy 6 luggers work just fine from any year. good hunting see daves hubcap solution: http://www.speedprint.com/Deves50/hubcapclips.php
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Mar 2006 Posts: 13 Junior Member | | Junior Member Joined: Mar 2006 Posts: 13 | if you plan to get new rims do you want to get rid of the old ones i need some call 205/296/0730 or email me at [email protected] thanks i might be able to help you on new ones
panelman
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | panel man you have email. | | |
