0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20576 05/13/2005 6:18 AM | Joined: May 2005 Posts: 5 New Guy | | New Guy Joined: May 2005 Posts: 5 | can anyone help me decipher the casting numbers? 3832441 g309? thanks in advance | | |
#20577 05/13/2005 3:47 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I believe the G309 says it was cast on July 30, '49 (or '59??). July is the G'th month. Someone else can chime in the on casting number.
What is it off of? How many bolt holes does it have. They changed from 15 to 18 bolts someplace in the 216/235/261 series. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#20578 05/13/2005 11:56 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I cannot find a head casting number for that head on any of the lists and I have all the lists. The first three numbers indicate a series of several heads, but the last four numbers are not listed. :confused: Possibly you are misreading the number or it could be a replacement head that was not manufactured as part of any engines built on the assembly line, but as a replacement for heads that cracked or warped or had other problems.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#20579 05/14/2005 3:06 AM | Joined: May 2005 Posts: 5 New Guy | | New Guy Joined: May 2005 Posts: 5 | they are off a 350 but they are toast thanks anyways | | |
