4 members (Shardean, Tstan7, 2 invisible), 94 guests, and 4 robots.
Topics128,022
Posts1,055,353
Members48,420
Happy Friday everyone.I am trying to locate where the temperature sensor is located on the engine ( 1951 model 1300 216 )the hard wire for the gage comes out of the firewall and was cut off.Also I am looking for the brake light switch.
It's time to get those working. Thanks for any help.
Brake light switch is on the firewall underneath the brake pedal, when you step on it the lever on the switch moves.
Temp. Sender on the mechanical guages screws into the head near the firewall on the driverside of the engine. If the line on the temp. guage has been cut you'll have to replace the guage.
Thanks NM51
I found the temp screw on part on the head. The brake switch may be missing something like the lever.I'll keep at it.
thanks again
