6 members (Gdads51, cmayna, Woodcmiami, mick53, MickeyP, 1 invisible), 41 guests, and 6 robots.
Topics128,012
Posts1,055,312
Members48,419
#205451 04/05/2006 3:29 PM
ok here we go lets see who can help 62 suburban 235 6 ok. here is my question i have no fuel tank so i run it of a gas can under the hood.now if i put the gas can in back where they had a fuel cell the truck dies and will not restart is it my pump or a pluged line
bill
#205452 04/05/2006 3:54 PM
Apprentice
Apprentice
I assume you were pulling gas out of the can under the hood using the stock fuel pump. If that's true, it sounds like the pump is O.K. If not, how was the gas getting from the underhood can to the carb?
Often, I've found that the line is not necessarily plugged but that it has rusted through somewhere and the pump is sucking air instead of gas.
If the pump is pulling from the underhood can, but not from the can when placed in the back it almost has to be the line--plugged or rusted through. Try disconnecting the line from both ends and shoot some air from a compressor through the line--you might hear a hiss from a rusted through hole or verify that it is plugged--it may even clear the line!
just my 2 cents...
51 1/2 ton-455 rocket!
49 1/2 ton panel-rocket-to-be!
#205453 04/05/2006 4:02 PM
i will try that and let you know
bill
#205454 04/05/2006 4:08 PM
found it 1 was the rubber fuel line they put in was split under truck the other was a small rubber line between 2 steel lines it would colaps so replaced them runs now
bill
