1 members (Forty9),
134
Mod | | | Forums66 Topics128,132 Posts1,056,385 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20543 05/10/2004 6:21 AM | Joined: Oct 2003 Posts: 5 Late 1953 6100 | | Late 1953 6100 Joined: Oct 2003 Posts: 5 | Is anyone running a 5/8" waterpump on a later 235? I just bought one and I've been advised that I would need to change the harmonic balancer and generator pulley to match. Is there a 3/8" pulley to fit this pump? | | |
#20544 05/10/2004 10:52 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | You can run a 5/8" pulley on a water pump on a 235 or 261. The older 235's had 5/8" pulley and I have run 5/8" pulley on a 261. I even ran a water pump with a double 5/8" pulley. It looked funky, but it worked. Your question can best be answered depending on what vehicle you have the engine in. You can go either way and I would go the cheaper way, but you may not be able to go that way if your vehicle restricts you from going that way. So - what vehicle are we talking about? :confused:
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#20545 05/13/2004 8:24 AM | Joined: Oct 2003 Posts: 5 Late 1953 6100 | | Late 1953 6100 Joined: Oct 2003 Posts: 5 | The water pump is for a 1960 235 car engine that was swapped into a 1953 Chevy 1 ton. I wanted a shorter waterpump so I was advised to get the adapter plate so I could use the earlier water pumps in the stock position. I bought a 5/8" pump in a moment of auction fever and now I still need: a 5/8" generator pulley,harmonic balancer to match the smaller pulley,a fanblade(2 1/4 boltcircle,5/8" center hole) and Pre 68 Dave's adaptor! That short shaft waterpump or electric fan or leaving the hacked radiator shell w/core forward are all looking pretty good to me now! So if anyone has any parts or shortcuts please let me know. Regards Peter | | |
#20546 05/13/2004 11:37 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Pete ,I have the adapter and 216 pumps on 3 of my running trucks with later 235/261's.Here's how I solved the pulley problem Water pumps adapting It works out great. | | |
#20547 05/13/2004 6:47 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I shortened the late style pump with a press and used a junkyard pulley off an ordfay. It had the same diameter and belt size, but a lot less dish than the original. I think one of those would fit on the 216 style pump too.
#20548 05/14/2004 4:42 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | After reading your comments and the other contributors to this thread, it sounds to me like you need the adapter plate "Truckedup" used on his truck to assure you have that high water pump position for effective cooling. If you use it, the shaft should be the right length to allow proper clearence for your fan. All you need to complete the change out is a 5/8" harmonic pulley and a 5/8" generator pulley which you should be able to find at most any wrecking yard which has been in business since the 60's or 70's. The other thing you can do is advertise in the "Parts Wanted" area of the swap meet section of this site. By going with this setup, your truck should look stock. Good luck!
