3 members (TooMany2count, Rich'sToys, 1 invisible), 74 guests, and 7 robots.
Topics128,021
Posts1,055,353
Members48,420
#20519 09/19/2003 4:08 AM
When I purchased my 1948 2-ton, it came with a 16psi cap on it, which concerned me. I drove it around fine until I could get the correct 0psi cap for it. Then it boiled over all the time, so I put the 16psi cap back on. What is the correct cap to use? I have the stock radiator, but I have a '54 235. Like I said, no problems yet, but it's pretty flat here, with almost no hill climbs.
'48 Chevy 2 ton Flatbed
(daily driver)
'70 BMW 2002
My truck is older than my parents!
#20520 09/19/2003 4:21 AM
I think the 1954 235 truck engine had a 4 lb cap and the car had a 7 lb cap.
Tim
#20521 09/19/2003 4:41 AM
Yep, I ran 4 psi cap on a '54 (or so) 235 in my '48 for 10 years with no problems. You might not have hills but it must get pretty hot there in the summer.
#20522 09/19/2003 5:16 AM
Drove it around fine when it was 109 here, but not for long distances. I'll try the 4psi cap. My stock radiator should be able to handle some pressure right?
(daily driver)
'70 BMW 2002
#20523 09/19/2003 4:33 PM
If the radiator and heater core held together with a 16# cap, a 4# shouldn't be any problem. Those are the parts affected. 4# cap was introduce on trucks in 52.
Things to do to lower the temp include:
1. Getting the radiator boiled to clean out the junk.
2. Back flushing the block. Also be sure that water will flow out the drain cock on the block, if not, clean out the watter passage with some wire.
3. Major tune-up that includes adjusting the valves and checking the timing, both can raise the engine temp if they're off.
Fred
52 3600
69 C-10
#20524 09/19/2003 5:32 PM
I run a 7 lb cap on my 261, but I have a brand new radiator and water pump. I tried the 0 lb cap and it didn't boil over but it did run hotter.
Paint & Body Shop moderator
#20525 09/19/2003 6:34 PM
Also, the radiator doesn't like to be full. it will boil over until it reaches a point it likes. Generally a few inches from the top. '54 is 4psi.
54 3100 with 235
62 flatbed dump C60 with 261
