| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | What fluid do you use in a steering box? Can I just 90wt?
1946 1/2 ton I'm not addicted I just don't know when to stop
| | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | There are several threads on this topic, try the search button at the top right hand corner of the page under the 'post new topic' and 'post reply' buttons.
If you are rebuilding the box or have it drained, don't forget to use permatex type 2 or 2a non-hardening sealant on the threads.
