5 members (rfs56trk, 55shaker, DadsFirstPickup, JoergK., 1 invisible), 324 guests, and 3 robots.
Topics128,152
Posts1,057,011
Members48,460
I checked LMC and American classic and it doesn't appear that they have it. Do you buy tie rod ends and make it?
This is the part I\'m hunting...click here
Any help would be appreciated..
"All right, they're on our left, they're on our right, they're in front of
us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC
Drag link.. I think that's it. Thank you very much!...
So the curved arm is called the steering arm?
What Year? I bought a drag link from Chevy Duty for my 53 for about $65. The one for the 47 to 52 had different ends and ia about $75
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
it's a '58...
you can get the TF drag links at NAPA - at least at the one up the street from me!
called the "connecting arm" in the manual - the one from the end of it to the steering box is called the "pitman arm" - the curved one is called the "3rd arm"
thanks red... most of the parts stores around here go to the mid 60's, then get all fuzzy eyed when you say '58. i went ahead and ordered the one that acwhite posted about, but will check NAPA to see if they're willing in the future..
thanks all.. cool
Definately try NAPA the one near me has a few service parts in stock. Front end, generators, motor parts, gaskets & seals have been delivered from their warehouse in 1-3 days most of the time.
I have a 56 Chev 3100with a 235ci 6 cyl & 3 spd manual trans.
Good Luck
Brad
SEE::
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=003275;p=1#000000
it may give you a starting point for your search
goodluck...
Jim & Caroline
thanks again all.. old chevie truck back ordered so I'll call NAPA in the morning.. If that doesn't work then it'll be golden state...
