1 members (klhansen),
61
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | How do you remove the knob on a window crank handle on a '52? Any help would be greatly appreciated. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | There is a wire clip, C shaped on the shaft under the handle. If you pull out on the handle a little and look under it with a light you can see it. I usually use a long, thin screwdriver to push the clip off. Another option is a tool like this window handle removal tool
Fred 52 3600 69 C-10
| | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Also a screw driver.First a cap screw,remove first.Under that is a set screw.Fred is talking about a jesus clip mostly on cars.Someone may have changed your handles and cranks
dan-pa
| | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | The way I understood the question I thought he was asking how to remove the knob from the handle, not necessarily the handle from the door. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Yep your right old gold.The eyes have it.Sorry. use a BFH.
dan-pa
| | | | | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | Old gold is correct, I am trying to remove the knob from the handle. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I'm not familiar with your application but I don't believe the OEM knobs were meant to be removed without destroying them. On occasion they would wear enough that they'd come off on thier own. Replacement knobs have specialty fasteners to hold them on. If you want to save & reuse the knob (maybe to rechrome the handle) that will be difficult I think. It can probably be done but without seeing the handle up close I can't give you a specific answer as to how. Maybe if you post a good, detailed picture of the handle/knob it will generate some good ideas. Good Luck.
| | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Highschool hauler, you have to drill the head off of the rivet and then the knob is trash. You can get replacement knobs from JC, CD and etc. If yours is a 52 you will need to get the maroon ones to be like orginial.
I did this to mine to have them re-chromed, the repo knobs look as good as the orginials. | | |
