| | | Forums66 Topics128,275 Posts1,058,439 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 5 Junior Member | | Junior Member Joined: Feb 2006 Posts: 5 | I am almost ready to pull 216, tranny and all, out of my 46 panel, and I'm not sure what the best locations for hoisting are. Any help would be greatly appreciated. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | The best spots I have found are at the back of the intake at the runner that feeds # 5&6 cyls and on the passenger side front there is a theaded hole that will take a 3/8 bolt with a large washer.Use a small chain looped around the intake then bolt it together.Work safe!
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Nov 2004 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 61 | I used lifting slings one on each end. But I pulled my 235 engine and bellhousing only, dropped tranny from the bottom. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If you don't have your front clip removed it's kind of tricky to pull trans and all, that's why you see so many with the top loop of the radiator support sawed off. You may have to hook to it twice, the first fairly balanced to shift ahead slightly and the second time toward the front to stand the engine-trans assembly nearly on end to clear the radiator loop. Be sure to drain both the engine and trans oil or it will get messy. The trans will want to hang on the bellhousing crossmember but with the right wiggling and cuss words it will come out. Much easier to seperate at the trans and remove in two pieces. Good luck.
Evan
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | A lot of people pull the grille,core support,bumper,splash pan,radiator, leaving the hood on. You can pull it right out the front with a good engine hoist.I plan on pulling mine this way. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you're pulling the tranny with the engine you need a load leveler. Like the others have said, On these trucks it's usually easier to pull them separately. If you have a floor shift box, you can pull the floor plate and use an engine hoist through the passenger door to lift the tranny.
As for bolts, I usually use a front and rear head bolt. Sometimes I use the front manifold bolt and the rear coil mount bolt. Don't lift by wrapping around the manifolds, they crack too easy and don't need your help starting new cracks.
Fred 52 3600 69 C-10
| | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Tim, where are you in Minnesota? I'm in Lake Elmo and have some extended eyebolts I have made to thread into the headbolt holes. Much safer than lifting by the manifolds! You're welcome to borrow them if you want. | | | | | Joined: Feb 2006 Posts: 5 Junior Member | | Junior Member Joined: Feb 2006 Posts: 5 | Thanks for all the helpful info. I'm happy to say the motor and tranny are safely removed and nobody got hurt and nothing was broken. I had to remove the shift lever and I picked by the head bolts. Now what to do with the old drivetrain ? Thanks again, Tim | | |
