2 members (baldeagle, LAROKE),
30
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Howdy, So, I'm considering the idea of putting a 454 from a 1974 Chevy 3/4 ton into my '56 GMC 1/2 ton but before I do that I'm trying to do some research on its power specs. I've found several pages like this one and this one But what I cannot figure out is why the horsepower is stated to be 240 HP net. It doesn't make sense when these big blocks were producing double that only a couple of years earlier. Can anyone fill in the blanks? Would a 1974 454 engine still be a stump puller or did GM take the wind out of its sails? Thanks, Zeke | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | 1974 is probably the worst year in terms of the impact of emission requirements on performance. It was the first year many of the new US regulations took effect and its before computer controlled systems were able to better manage timing and fuel to get the power and milleage performance of today.
Its still a powerful motor and one from a pickup was not hurt as much as a car motor. And changing heads and manifold and other pieces of the combination will wake it up some.
I love my 454 and want to put one in every truck I own.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | HP ratings are all over the place on same size engines, even within the same year.
I don't know alot about the subject, but i've been pretty supprised to see some pretty gutless HP ratings on some pretty big engines in the past.
I used to think 'bigger meant more horses' but the more I read, that's clearly not the case.
Alot of it has to do with the engines intended use.
| | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | They also changed the SAE horsepower ratings around that time to reflect a different standard... those Engines still have lots of power..
| | | | | Joined: Oct 2005 Posts: 10 New Guy | | New Guy Joined: Oct 2005 Posts: 10 | My dad put a 454 out of a '74 truck into his '67 truck. It ran circles around my '67 that had a 283. He could also pull large trailers up big hills without slowing down.
bw
| | | | | Joined: Jan 2005 Posts: 164 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 164 | RROd is right, in the early 70s manufactures had to change from gross ratings (stripped down engine) to net: engine with all the exhaust, power accessories, alternator, air filter, etc. installed | | | | | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | I had a 74 454 ElCamino for a brief time. It was a dawg. It was in good tune and I didn't want to hack the air pump and other stuff off it at the time but it was a slug. I owned it for all of two months. The 1974 350 equipped truck could out accelerate it. There was a Road&Track article in the day that compared the two. Now, that's not to say that a set of heads and an intake manifold wouldn't wake it up. As produced however, the 1974 454 was a real slug. Cam, heads, compression all combined to make it so. Cheers, MV | | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | Three words Smog Smog and Insurance. Bad words I know but thats why the horsepower went away. Emissions standards knocked down the power and insurance companys killed you in the wallet if you had more horsepower. Not a good time for muscle. | | |
