| | | Forums66 Topics128,131 Posts1,056,367 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 13 Junior Member | | Junior Member Joined: Jan 2006 Posts: 13 | Will a big bolt cab accept 1/2 ton front fenders, or is the cowel larger? | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | It'll work on the 39 thru 53 trucks for sure.. not sure about other years.. unless you're talking about putting 1/2 ton fenders on a Big Bolt truck frame.. then I think it only works up to a 1 ton.
In the '39 thru '46 trucks, I think the only difference between 1/2 ton and 1.5 ton fenders is the wheel opening and maybe the width.. the hoods are interchangable.
In the later trucks, I understand the hood is longer, which would suggest the fenders were longer?
| | | | | Joined: Jan 2006 Posts: 13 Junior Member | | Junior Member Joined: Jan 2006 Posts: 13 | Great news! Thanks for the help! | | | | | Joined: Dec 2005 Posts: 47 Member | | Member Joined: Dec 2005 Posts: 47 | I bought a complete front end to use on my 51 half ton and the fenders are too wide and the hood is slightly different. One hood is rounded at the corners and the other is straighter. Don't remember which is which. The cabs are the same though.
Heres to us and those like us, theres darn few left.
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | The way I understand it the 'Advance Design' trucks, 74 thru 50 whenever used all the same cabs on all the trucks 1/2 ton thru 2 ton.. and that the 1/2 ton trucks thru 1 ton trucks used the same fenders, hood, and grill. The 1.5 and 2 ton trucks had bigger fenders and a bigger hood.
The 50's GMC 1 ton near me has what appears to be 1/2 ton and 3/4 ton sized front fenders.
So provided we're talking about an AD truck, if your fenders are too wide to fit on your 1/2 ton, that's probably beacuse they're off a 1.5 ton or larger truck.
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The hood that is pointed at the rear corners is for a medium-duty truck, and is longer than the light-duty counterpart. | | |
