Brrrr
place holder
9 members (Hush, 41 chev, Peggy M, Charles in CA, Bucker, klhansen, Nick in Manitou, Otto Skorzeny, 1 invisible), 105 guests, and 6 robots.
Topics128,270
Posts1,058,408
Members48,485
#20250 11/18/2002 9:07 PM
Junior Member
Junior Member
My question is : Do these GMC motors of this vintage (guessing 228 ci) have the same firing order as the Chev 235 1,5,3,6,2,4 ? Is the firing order casted on the block or intake anywhere, like a sb chev?
If it does, then the wires may be in the correct order, but in the wrong place. The engine seems to backfire out the carb, like the timing is off. So rather than keep on trying or pulling the truck to start it, I thought we should check a few things out first.
The next step is to find the compression stroke on number one cylinder and install the wires according to the position of the rotor and firing order.
Rapper1
#20251 11/18/2002 9:45 PM
The firing order on a GMC 228 is as you listed ,,
1-5-3-6-2-4..
Scrape off the flat part of the block to the left of the distributor. There should be a number
A228xxxxxx
to tell you if it is a 228..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
