3 members (Bill Hanlon, Erniegp, festerhairball), 86 guests, and 2 robots.
Topics128,054
Posts1,055,781
#202211 02/26/2006 4:18 PM
i need the bed mesurment from outside edge to outside edge of the fenders frount and rear to see if frunt end and rear end will fit off a 2001 chevy truck i hope it will.to retain the 6 bolt lug pattern.help please
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
#202212 02/27/2006 2:31 AM
X
X Offline
You can check the '46 dimensions here.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#202213 02/27/2006 7:37 PM
I can tell you the fender dimensions on that diagram are the same as my 1940 as well.
Basically the truck is about 72 1/2 inches wide.
Bill Schickling
1940 1/2 ton, 1940 3/4 ton
My web page
#202214 02/27/2006 8:38 PM
If you post your question in the Building a stovebolt bed forum the guys from Mar K will have the info that you need.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
