8 members (Guitplayer, klhansen, fonz8261, cmayna, Lightholder's Dad, Hotrod Lincoln, RLB, 52Carl),
87
Mod | | | Forums66 Topics128,192 Posts1,057,229 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 20 Member | | Member Joined: Mar 2005 Posts: 20 | Does a 62 chevy truck have coil springs or leaf? I have a 66 and it has coil but was wondering about a 62 my 52 has leaf springs. Thanks in advance for your help.
Dave | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Chevy came with coils and had an option for leaves. GMC's came with leaves and had an option for coils. Probably is coil. Is it a half ton?
Correct me if I'm worng.
Colin | | | | | Joined: Mar 2005 Posts: 20 Member | | Member Joined: Mar 2005 Posts: 20 | Thanks for the reply guess I'll have to just look and see Thanks for the info | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Actualy guys I believe the stock suspension for 60-63 was torsion bar front, coil spring rear. | | | | | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | 60-62 was tortion bar front end. '63 switched to independent a-arm front end. Yer right about coil spring rear.
Attitude - The difference between an adventure and an ordeal! Deja Moo - The feeling you've heard this bull**** before! '63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red' '69 or'70 or ? Mantaray DuneBuggy
| | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | My 61 has rear coils. I am going to be getting rid of them soon in favor of a set with about a 3 inch drop. Would the leaf option have been on the heavier service trucks?
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | |
