5 members (HandyAndy, Ponchogl, dt235sd, mason86, Cosmo), 112 guests, and 2 robots.
Topics128,047
Posts1,055,662
#201987 02/23/2006 8:08 PM
anyone in the dallas area have a work area/garage i could rent or borrow for a few days to do my disc conversion??? would need in 2 or 3 weeks or so.
thanks in advance
#201988 02/23/2006 8:26 PM
I have 11 acres, small frame house,etc, south of canton,,about 62 miles from Mesquite,,,,you're welcome to use it,, just dont have any garage or real cover,, have a barn but no door wide enough to get your truck in,,,, we could move the 70 International from under the car-port and you could use that for some cover if you need it,,, I only go there about twice a month,, you are welcome to use it....no charge,, just let me know, I will tell you how to get there and will probably be able to meet you there for the first trip....If you are at the meet tomorrow we can talk about it more to see if it might work for you,,,,,,,,,,,,,Fred
Redryder pix
My Hotrod
#201989 02/23/2006 9:20 PM
not going to make the meet. i have an open spot to work on it really looking for a covered or garage spot if i can find one close by. Thanks for the offer though
#201990 02/23/2006 9:36 PM
roger,,, sorry , you cant make the meet,, Fred
Redryder pix
My Hotrod
#201991 02/24/2006 3:54 AM
What have you got going on? Did you get bolt on bits or did you get stuff from a newer truck?
#201992 02/24/2006 6:30 AM
arnswine:
I came into a little cash and decided i would tackle the swap myself and buy all new parts. i wanted drop spindles and needed new calipers not to mention all the steering parts. after looking at prices and all i just decided to spend a bit more and buy a kit instead of spending the money having someone else install the old stuff. im just going to purchase everything new from cpp or chevy duty. still unsure if i want to purchase the booster/mc/prop valve new or reuse what i have. the problem is it has no brackets or push rod. The guys selling the kits are keeping a tight lip about the components that work so im not sure what brackets or rod it needs to work and dont have time for trial and error. once started i need to complete the swap ASAP.
#201993 02/24/2006 8:10 AM
So the kit sez just use what you got then? When I did the 59 I got a new dual circuit master and changed up the system. That of course changes up the brake lines. What about the kit, have you been through the instructions? How ugly does it look?
#201994 02/24/2006 2:28 PM
well theres 2 kits needed. the brake kit and the booster kit. but if i can find a better deal on a complete kit that would be better. im thinking i might just do this at home. one wheel at a time then the booster etc. spread it out for 3 seperate days. i just dont like the idea of leaving a job half done in my apts parking lot.
the instructions from CPP look nice and easy... but you know how that goes... heres a link to the tech article online:
http://www.classicperform.com/discdrop.htm
it is for a 67-70 truck but dosent seem that much will be different
and heres instructions on installing the booster for the 60-66
http://www.classicperform.com/tech_articles/OneStopBraking/OneStopBraking.htm
#201995 02/26/2006 7:34 AM
well, the reason I asked is I was wondering if we could get it done at my place post-haste. I don't want your junque pile replacing my junque piles for any real length of time. I did the single/dual conversion on my 59 - and with extra stuff to do - it took about a day. The spindle change looks to be the biggest pain in the butt part.
#201996 02/26/2006 7:04 PM
yeah I understand. i dont want to put any body out. hopefully some good weather is on its way. also coil over has offered a bay in his shop to me. its quite a ways away near bonham i believe but if no other oppurtunity arises that is an option.
#201997 02/27/2006 7:57 AM
Do you have the bits together yet?
#201998 02/27/2006 4:24 PM
deposit the check today and order stuff tomorrow.
#201999 02/28/2006 7:54 AM
Lemme know when it gets in. I'd like to look the stuff over and get a feel for what it would take. I have a bunch of tools including gas and electric welders etc. I also have to see how my junque shuffle will work. I have 4 vehicles in the driveway right now.
#202000 02/28/2006 4:21 PM
right on. appreciate it even if it doesnt work out. looks like more rain in the forecast for this weekend... we are entering the darn monsoon season here in texas
#202001 03/02/2006 9:25 AM
Yeah, ya got dat rite. Been really nice (tho a bit hot) for the past couple o daze. I'd think if we could get the bits together we could get maybe one of those jobs did over a weekend (weather permitting). Maybe both.
#202002 03/02/2006 4:43 PM
Yeah. Looks like if everything went smooth it could be completed in a day. it is a bolt on conversion, i just hope i can get the old stuff unbolted! ordered the kit yesterday and they say i should have it in 5-7 business days. i'll holler at you when it comes in. still waiting to hear back from CPP on the booster. want to discuss something before i buy...
#202003 03/03/2006 1:21 AM
Well, I have a gas welder so we can heat stuff up and that always works to get things undid. (That or I'll cut it off in blue flame speed mode! wink )
#202004 03/03/2006 4:38 PM
sounds good. about to order the booster. im tired of waiting on CPP so i emailed Performance online and asked if they have what i need. they got right back to me and price is cheaper than CPP. im tired of messing around with them. no answer when i call and no reply to emails... not to mention i have stuff still on back order from the beginning of January!
CPP just lost a customer for good!
