| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20175 11/04/2003 1:05 AM | Joined: Mar 2003 Posts: 49 Member | | Member Joined: Mar 2003 Posts: 49 | I have decided to rebuild the 350 in my storage shed instead of using my freinds 292 for the motor swap in my 59 chevy panel. In searching for a good rebuild kit for the 350 I noticed a few 383 kits for about $200 more. I know the 383 will require a 400 balancer and flex plate but I was wondering if anyone could relay any experiences good or bad in building or running a 383 smallblock. Some of my concerns are reliability, gas milage and overheating. The smallblock will be connected to a th400 and 3.07 geared 10 bolt from a 73 truck. This will be a long distance driver. | | |
#20176 11/04/2003 11:10 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Pay special close attention to the cheapie 383 stroker kits. Make sure you're getting good parts, such as forged pistons with correct pin height, new correct-length rods, quality crank, bearings, rings, etc. Pay attention to what your resultant CR will be with the heads you want to use. Your swept volume will increase by 4.125 CID per cylinder which will up your compression ratio. The 400 SBC crank has a 1/4" longer stroke, 3.75" vs 3.48" so you will have to clearance the block for the rod throws. Have the block zero-decked to prevent the slugs from being way down in the holes. Most high HP 383s require custom rebalancing and 4 bolt main caps.
A well built 383 will outperform a 350. Careful parts selection for your application is important. Most machinist/speedshop guys may assume that the 383 is for racing, and pick parts accordingly. Make sure you don't build a race motor that has no place in a work truck.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
