2 members (VicZ, klhansen), 118 guests, and 3 robots.
Topics128,072
Posts1,055,904
Members48,429
#201516 02/19/2006 1:42 AM
Would like some advice or maybe just what you guys think.The 216 I have has been rebuilt and has only about 2 hrs running time on it,at 180 water temp,at high idle it has about 15 to 17 lbs oil pressure,at idle it has 5 to 7 lbs pressure.I am not able to take it on a road test,still have to wire,and put front end and rear fenders on.I have a 235 ready but I would like to give to 216 a chance.Is this oil pres. normal or is it to low,Have 10-30 in it and 1 qt of Marvel.
Thanks for any comments, DON
Mr.Giant
1953 Chevrolet 3100 in the Gallery
1959 GMC 860 Single Axle Truck Tractor in the Gallery
#201517 02/19/2006 1:51 AM
Sounds about right to me Don. The 216 in my 41 from initial cold start will build up pressure to the top of the gauge and when warm at idle about 5 - 7 lbs. This is on an engine with less than 10,000 miles on it since it was rebuilt. Give the 216 a go mate. As long as you don't over rev it, its a great little engine.
Cheers
Bob
#201518 02/19/2006 4:54 PM
That's about normal. I think you should look at he oil your using. I've heard that multi-viscosity oil will cause build up on the top of the pistons. most people will recommend a straight 20w for winter and 30w for everything else. Look at the past posts on that.
1941 AK named "PETEY" my buddy.
#201519 02/19/2006 7:41 PM
Ex Hall Monitor
Ex Hall Monitor
You're OK. "Normal" on my 38 is 13.5 @ 2621 RPM. Tweak is correct on the recomended oil viscosity although I might add if it's very cold (below 0) 10 weight is recomended and the recomended change point to 30 weight is 50 deg.F. Personally I add a quart of synthetic because of the superior lubricating properties. These engines let all of the oil drain to the pan when shut off. I want a little extra protection on cold start/restart.
#201520 02/19/2006 8:50 PM
I also agree.. sounds like what both my splash oil 216 and 235 have for oil pressure.
I put a set of aftermarket gauges in the '46 1/2 ton just because the stock temp and oil pressure gauges were questionable in their readings.. when I first start it, the oil pressure is in the 20's, but as it warms up, the pressure drops quite a bit.. to between 5 and 7 at idle, and around 13 while driving.
#201521 02/19/2006 11:08 PM
i'm support all the previous comments.
relax, it just takes a little getting used to near non-existant oil pressure.
#201522 02/19/2006 11:49 PM
Thank Guys,When the books said the 216 was a low oil pres engine I did not know how low.I will change oil to 30W.thanks for all your help. DON
Mr.Giant
#201523 02/20/2006 12:00 AM
I believe you are good to go on oil pressure and I agree that the oil weight is important. I would take that 10-30 weight out and put in 20w until warm weather then pop in 30w.
Some of the more experianced on here will chime in on multi grade oils and I think you will find that you are dropping some pressure with 10w on the low end of that multi scale.
I like 20w30 but cant find it around here.
Hobert
"The Lord is my shepherd"
#201524 02/20/2006 1:04 AM
Those pressure numbers are spot on. In some of the Chev documents they don't list a minimum pressure for idle.
1951 1 Ton Completed
