2 members (3B, Cosmo),
149
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Hey guys, Remmeber the hard time I had removing the king pins from my 53 3/4 ton. Well reinstalling them isn't mich more fun.
I was able to press the bushings in with my vise and a piece of brass pipe. But I am not sure if I should push the pins in. The shop manual says you need to ream out the bushings once they are installed in the knuckle so that the pin will fit. Is that still true with todays parts? If so where do I get a reamer??
Thanks Rich | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Rich, if you have installed the new bushing, then the hole must be reamed out to the proper size, so that theres no binding. I always have mine done at the local truck repair place, as they have the correct reamers for the job. I wouldnt advise you to just press the pins in with being for certian that the holes have the right anmount of clearance. Hate to see you have to start all over again. I dont know where to buy a reamer, maybe some shop or the place where you got your pins could help you with that. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Rich,
Welcome back..sorry it's on a sour note. Your post is interesting to me because I thought I knew how this was suppose to work. I was even allowed to put a few side notes on the Tech Tip page regarding king pins.
If you have read the Tech Tip on this, it mentions that everything up to 1 1/2 ton is the "push in" floating type.
I thought other folks who had done the smaller trucks, such as yours, have indicated the bushing pushes into the spindle with moderate palm pressure, and the pin, also installs into these bushings with a hand push fit...everything floats.
I wonder why yours is different? If you have pressed the bushings in, and they are tight, so be it..it's OK. This is how many rigs work.
The proper next step would be to take the spindles to a automotive machine shop where they will "fit" the pins to the bushings for a nice sliding fit. This whole scenario is how you would address it on a big rig anyway..maybe you ended up with a king pin set from a larger truck..I don't know if they would interchange.
All is still good in king pin land, it's just a different song to dance to.
Stuart | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A machine shop can ream them out. Take the pins & spindles to them. They generally use a piston pin hone. Make shure the grease hole is linned up. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Thanks guys,
In the book it says the bushings should be reamed to fit. Unfortunatley I didn't read the book until Saturday. (bummer) Anyway I will take these to a local spring shop that does king pins. In the mean time I will putter with other things.
atomarc, I was unable to post for a while. My wife was very sick so I was busy tending to her. She is fine now and almost ready to go back to work (thank goodness...I was tired of her finding things for me to do while she was recovering)
I am assembling my rear brakes tonight. Man those new springs are tight!
Rich | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | If you spin the bushings and the grease hole moves, just drill a new hole. It'll hold more grease.  | | | | | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | The "1/2 ton" is the ONLY truck that has the "floating" push in bushings that do not require "outside help". Your 3/4 ton has bushings that press into the knuckle and then reamed to fit the king pin. This link is to your particular front end, but I think it is typical for the 1947-1954 A.D. trucks. http://chevy.tocmp.com/chevyresto/53130.htm By the way, this is restoration pack series and it is the only place I have found this information. I was unable to find it in the Service Manuals. P.S. Take that axle to a competent machine shop to have that bushing reamed to fit the king pin IMHO
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
| | | | | Joined: Nov 2005 Posts: 39 Apprentice | | Apprentice Joined: Nov 2005 Posts: 39 | 49_chevy_truck Thanks for the info! I have a 51 1/2 ton and I am also doing my king pins. They came out like a greased pig! I sure hope they go back in like one...waiting for their arrival from Chevs. of the 40's.
1951 Chev.P.U. Streetrod-project 1951 Chev cpe 261 5-speed-50% 1953 Chev cpe 350/700-95% 1962 Chev Bubbletop 409 -75%
| | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I had my bushings done at Duff Spring in Medford. The pins went in nicely. I wll be putting th rest of the front end together this weekend (I hope...It si snowing like crazy right now)
Thanks again guys for all the advice! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If the tech tip says that everything up to 1 1/2 Ton has floating kingpin bushings, then it needs to be corrected.
After reaming, the kingpin should slide in without force but without play. The light press fit should be referring to the fit in the axle. | | |
