7 members (Charles in CA, Otto Skorzeny, Lonnie, 1955 1 Series, dt235sd, Wickedbass, 1 invisible), 125 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#20093 01/17/2005 8:37 AM
i just bought a 64 c30 flat bed truck for 150 bucks. its complete and is actually not that bad in many repects for only 150. anyways....it has a carter carbuerator that looks almost identicle to all other stock one barrel carbs ive seen on these kind of trucks. what kind of carb did the 64 chevys originally come with? i always thought they were rochesters, but this carter looks like it belongs. anybody know for sure?
Riding in the Passing Lane
It originaly came with a model B rochester. If the Carter is hooked up properly & is calibrated to the engine it is better than the roch. smile
1972 Chevy c10 Cheyenne Super
really? well thats good to hear. thanks for the response, ill go with that then.
Junior Member
Junior Member
Why is the carter single barrel carb better then the Rod B carbs?
I thought that is was the other way around.
