1 members (Mike Roache), 58 guests, and 1 robot.
Topics128,078
Posts1,055,938
Members48,430
#200579 02/09/2006 1:38 AM
Junior Member
Junior Member
I have a 66 1/2 ton with factory power steering but I need to change the steering box.I have a manual steering box off a 66 .Does anybody know if they are the same or would it work?They look the same to me.Thanks
#200580 02/09/2006 7:44 PM
The power steering box should have two fittings for the power steering hoses. Without them, no power steering. Also, a lot of the boxes had different size shafts for the pitman arm, making the swap difficult.
Fred
52 3600
69 C-10
#200581 02/09/2006 11:26 PM
Riding in the Passing Lane
The 66 used the old linkage power str. The steering gear itself will fit. It may have a different ratio but will still work. Count the turns from lock to lock & compare.
1972 Chevy c10 Cheyenne Super
