8 members (C10 - C90 Bill, Donf, DoubleB, Otto Skorzeny, Gdads51, Hanks custodian, Forty9, 1 invisible),
40
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,020 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | I am finally working on my dump bed for my 1950 2 ton. Would it work to use one of the 12 volt hydraulic pumps with reservoir and the original low pressure cylinder? The valve in the original hydraulic pump looks a little flakey and I would need a driveline. The original linkage was a mess and I would need to redesign all of it. It would be a lot easier to run a few wires if it would work. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | rdbates,
Those units are very slick. I would not hesitate to use one. The ONLY killer is the freight to get the big old moose to your door!
Stuart | | |
