6 members (Gdads51, Hotrod Lincoln, Steelonsteel, Otto Skorzeny, Wally / Montana, 32Fordpuchoptop), 49 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#199781 01/31/2006 5:21 AM
I am finally working on my dump bed for my 1950 2 ton. Would it work to use one of the 12 volt hydraulic pumps with reservoir and the original low pressure cylinder? The valve in the original hydraulic pump looks a little flakey and I would need a driveline. The original linkage was a mess and I would need to redesign all of it. It would be a lot easier to run a few wires if it would work.
#199782 01/31/2006 5:23 AM
rdbates,
Those units are very slick. I would not hesitate to use one. The ONLY killer is the freight to get the big old moose to your door!
Stuart
