1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 65 | Can anyone tell me what the stock bumper height is for a 1950 3100? A measurement at the front of the running boards would also help. Thanks, Bob
1950 Chevrolet 1300
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Hi Bob, Here's a link to the dimensions page of the 1953 resto-pak. Looks like your front axle should be 8 1/8" off the ground. I would check my truck for you but it's in hibernation right now. http://chevy.tocmp.com/chevyresto/53060.htm Curt
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: May 2005 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 65 | Thanks Curt, With the broken spring and no motor or front sheetmetal the axle is sitting close to that. Haven't checked the spindles yet but pretty much everything else is either bent, broken or worn out. Looking at a few suspension options: stock, monoleafs, mustang II. In no rush to decide but I want to start collecting parts, seems less painful than buying everything at once. Bob
1950 Chevrolet 1300
