2 members (VicZ, klhansen),
118
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | I read a magazine article that showed the use of Carbon fiberboards to build a truck bed and it looks like a great Idea. Have any of the stovebolters used these synthetic boards. I like the tech tip advice for building one for the bolt. Here is what I am Guessing about the carbon fiber Good: will not soak up water, expand and rot,will retain color without restaining, will look good with stainless steel metal strips holding it in place. Bad: Do you think it would be too light to hold the truck down? How about when it gets scratched-will it turn grey or whitish looking? please help me out on this. Thanks in advance.
1946 modified one ton flatbed | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Ive worked with carbon composites for over 20 years so I might be able to help. Carbon will wick up water. Not as much as wood but it does happen. Any cut edges need to be edge sealed. It will not rot you are correct but it can degrade if not edge sealed. The freeze/thaw cycle would be an issue there. I'm not aware of the staining properties so I can't comment there. The weight will be an issue. If you don't have something on the bed that weighs a lot you'll have a more difficult time getting traction. I don't know about a scratch turning grey over time, I only worked with new parts. It will provide an avenue for water migration if not sealed though.
| | | | | Joined: Nov 2005 Posts: 146 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 146 | and dont forget the cost factor. even though the cost of carbon fiber products have come down, im sure its not cheap. :confused: | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | sounds expensive to me, but i am kind of a tightwag. as for the weight issue you coulp add weight under the bed if you felt you lost too much traction. i would investigate thourougly, but it sounds cool. do it and report back to us.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | |
