| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 58 'Bolter | | 'Bolter Joined: May 2004 Posts: 58 | Hello, can anyone tell me if their cabs have been factory notched at the seam of the toeboard and floorboard, on the outside near the clutch and brake levers? I currently have six other cabs, and I have checked at least another six cabs, belonging to a friend of mine, and ALL of them have been notched at the seam. Thanks in advance.....Clint | | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | whats the year of your cab? and is it chevy or gmc cause i think the cabs might of been different in the older years (i'm not sure on that) Nate | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd guess that if you've found the same identical 'notch' on 12 different cabs, then it's a pretty safe bet it was factory, or they've all been thru the same body shop for the same 'modification' Bill | | |
